Power steering fluid
Old Nov 3, 2002 | 01:42 AM
SuperTrans Man's Avatar
Car: Camaro
Engine: 5.slow
Transmission: 5 speed manual
ok i think.... my car has a power stering fluid leak, there seems to be a leak under my car by my front left wheel a red-orange fluid and im kinda concerned about what i should do to fix it and what its coming from cuase i cant seem to find the sorce of it it so i cant figgure out how to fix it if someones had a similler problem or knows how to fix it or soemthing i could do to figgure out where its comeing from it would be most appriciated
Old Nov 3, 2002 | 05:55 AM
radiateu2's Avatar
leak
more than likely it is coming from the return line behind the resevoir on your powersteering pump. Hoepfully all you have to do is tighten it if you can. Its in a tight spot
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
backtothe80s
Sep 5, 2015 12:39 AM
sailtexas186548
Aug 24, 2015 10:11 PM
