Rod Knock
Old Nov 3, 2002 | 09:07 PM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
Rod Knock
I have been offered an old 350, but I am told it has a rod knock and of course has to be rebuilt. What exactly causes rod knock? Bad bearings? Bent rod hitting the cylinder walls?
I may have it machined to make a 383 but would a rod knock cause damage to an engine to make it unsuitable for a performance engine?
Old Nov 3, 2002 | 09:32 PM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
As far as I know a rod knock is usually caused by a bad rod bearing. Usually the bearing will go bad and chew up the crank journal that it's on. Sometimes the particles can get around and eat up an entire engine. Just don't count on reusing the crank or the rod(s). Also make sure the block is checked thoroughly before being machined.
Old Nov 4, 2002 | 06:25 AM
ede's Avatar
ede
about every time some one says an engine has rod knock it doesn't. people like to assume the worse and not truely ID the noise. at any rate i wouldn't let it scare me away from the engine.
Old Nov 4, 2002 | 10:50 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
piston slap maybe? if so its bad rings and if it is really bad the cylinders would be ipretty bad shape to
RedLeader289
May 28, 2019 01:47 PM
Ed1LE
Sep 30, 2018 09:14 AM
bigjay89gta
Oct 15, 2015 08:04 AM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
