How do you make the gaskets fit SLP runners??
Old Nov 7, 2002 | 05:13 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
I'm thinking about SLP runners, they seem like the best deal for aftermarket runners. If I get these I'll want to siamese the plenum to match the runners. My question is how do you cut the gaskets to match the siamesed openings without creating vacuum leaks?
Old Nov 7, 2002 | 05:33 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
With scissors
Mr. gasket sells uncut gasket material in various thicknesses if you
can't trim the accel gaskets.
Old Nov 7, 2002 | 09:28 PM
rezinn's Avatar
You probably won't want to use scizzors since the gaskets they come with have a metal layer inside. Some kind of sheet metal cutters will work better.
Old Nov 7, 2002 | 10:26 PM
Vader's Avatar
What's worse is that the OEM Gm gaskets and FelPro replacents don't even fit the stock runners. I punch them with a 1¼" trade size (1.660") conduit punch to get them to fit correctly.
Old Nov 8, 2002 | 09:24 AM
Morley's Avatar
Use Rol gaskets, they fit much better. And use a good pair of dikes (diagonal wire cutters) to cut the center portion of the gasket out for SLP runners
1992 Trans Am
May 10, 2023 07:19 PM
Jeremys87
Jul 14, 2022 09:08 PM
tazs2000
Jul 15, 2017 08:44 AM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
NinjaNife
Aug 23, 2015 11:49 AM
