HEI Distributor
Old Nov 8, 2002 | 06:58 AM
usa1racing's Avatar
HEI Distributor
I'm thinking of changing from TBI to carb, and changing the cam from hydraulic roller to solid flat tappet. I believe I'm going to use a standard GM HEI distributor correct? Vacuum Advance? Are there HEI distributors that came without vacuum advance, and if so, can they be converted to vacuum advance? Any other advice? Thanks.
Old Nov 8, 2002 | 08:40 AM
ede's Avatar
ede
not sure what you're asking for, ecm controlled distributors don't have vacuum advance, non ecm controlled distributors do. you need a non ecm controlled hei distributor for your swap
Old Nov 8, 2002 | 12:47 PM
TBurke's Avatar
Get an older style HEI w/ vaccuum advance or get an msd timing computer to control advance.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
skinny z
Oct 5, 2015 06:23 PM
Damon
Sep 26, 2015 04:29 PM
