Airflow in ducts with different shaped openings
Old Nov 8, 2002 | 11:18 AM
Sciguyjim's Avatar
Here are the airflow efficiencies I found in a library book for smooth duct openings with different shapes. (Ignore all the dots, I had to add them to get the solid lines to position correctly.)
_________
_________
Plain opening with sharp edge, efficiency = 72%
_________|
_________
Flanged opening, efficiency = 82%
_________/
_________
Funnel-like tapered opening, efficiency = 90%- 98%
Angle of taper 20° to 65°
Curved "Bellmouth" shaped opening, efficiency = 98%
...............______
_________|
_________
..............|______
Can type opening, efficiency = 82%
................._____
__________/
__________
................\_____
Can with funnel-like tapered bottom, efficiency = 90% to 96%
Can with curved bellmouth shaped bottom, efficiency = 97%
The sharp edged plain opening is the least efficient because most of the air is sucked in from right next to the duct. As it makes the sharp turn into the duct, its inertia makes it overshoot a little bit and the flow constricts to as little as 70% of the duct diameter a short distance inside the end of the duct.
Old Nov 8, 2002 | 09:55 PM
Vader's Avatar
Do you think it's a coincidence that the third example looks a lot like an exhaust valve? Or that your last example looks a lot like the TB opening on a TPI or LT1 engine? Those guys at the factory must've read the same book....
Hotrodboba400
Dec 10, 2019 07:07 PM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
dbrochard
Oct 3, 2015 12:43 PM
Ian Irvine
Sep 4, 2015 08:08 AM
luvofjah
Sep 3, 2015 07:08 PM
