Cost of EGR
Old Nov 8, 2002 | 10:38 PM
Joeboy's Avatar
Cost of EGR
I failed inspection because my EGR was block and the hose wasnt connected. Whats it gonna cost me to get a new EGR and fix it?
Old Nov 8, 2002 | 11:07 PM
TBI305Camaro's Avatar
EGR valve and gasket for our cars is ~30$ tops. I cant remember off the top of my head. Real easy to fix tho. Only two bolts that are on studs behind the TBI or carb. Very simple. dont try it when the engine is hot tho.
Old Nov 9, 2002 | 08:23 AM
Vader's Avatar
Joe,
What engine do you have? The TPI engines require a negative backpressure EGR valve, and the system is so sensitive to pressure differential that I would be very leery of anything but an OEM (AC) EGR valve. In TBI applications, I've had success with the aftermarket valves with the staked-in orifice washers, and those can be purchased for $30-40. Add to that the cost of a gasaket, a can of carburetor cleaner and a small, stiff brush (to clean the passages), and a jar of Never-Seez (to coat the mounting bolts) and you might be pushing fifty bucks. On the brighter side, with a working EGR you should be able to run a little more timing advance and save enough fuel to pay for the valve in short order. 94 octane is about $1.72 around here right now.
Old Nov 9, 2002 | 08:52 AM
Jza's Avatar
Jza
My TBI's EGR had external Torx bolts instead of regular hex bolts like my TPI car does. The tools were an added investment to that job...
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
