whats egr??
Old Nov 11, 2002 | 03:11 PM
bad_ta_05's Avatar
Car: 85 trans am
Engine: 79 4 bolt 350
whats egr??
i have been lookin at intake manifold and they say with or without egr, what is egr and how do i know if i need an egr or non egr manifold? thanks
Old Nov 11, 2002 | 04:18 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Exhaust Gas Recirculation.
It is an emissions control system that lets a little exhaust back into the intake when the engine isn't under a large load, like when cruising, to reduce cyl pressure and therefore NOx emissions. It is necessary on some stock motors to allow the full ignition timing advance to be used. Without it, you may get spark knock.
If you are retaining your computer controls, or if your locale has a visual emissions inspection, get one with it. Otherwise, you can do away with it.
Old Nov 11, 2002 | 04:24 PM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
Also, Check this out:
https://www.thirdgen.org/newdesign/t...diagnose.shtml
This is from the technical articles page on this site which is here:
https://www.thirdgen.org/newdesign/tech/
Got some time? Read them all, they cover just about all the basic knowledge you should know about your car.
Also, use the search function on this forum when looking for answers to broad questions like this one. This question has surely been asked before and if you find that post, you can rest asured that the answer is still correct.
Keep On Keepin' On
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
