Has anyone done intake upgrades on a TPI 305??
Old Nov 11, 2002 | 07:46 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
I'm just wondering if anyone has put any hi-flow TPI parts on a 305? I was thinking of SLP runners, porting the plenum, and if it's worth it looking for a high flow manifold. I want to know if any of you have done this and what kind of results you found? Thanks.
Old Nov 11, 2002 | 08:58 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Yes, throw a LT1 intake on there and be done with it.
I've got some that came from the 4.3L V-8 in Roadmasters, Carpices and the like. If a little 4.3 V-8 can be run by a LT1 intake then your 305 will love it.
You will not run out of intake anytime soon either, there have been stock LT1 intakes run 10's in the 1/4 mile.
lastly, it's about the same price as a good set of aftermarket runners or base TPI intake.
Old Nov 11, 2002 | 10:23 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
I appreciated the idea but that's a little more custom work then I'm ready to take on or worry about right now. I will keep the idea in mind for later on down the road though.
Old Nov 11, 2002 | 10:35 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
In that case, save your money than for some major upgrades. Not being a dick, but letting you know there is not that much improvement over stock with those parts on a 305. And they are all expensive! Once you mess with more air flow, you should mess with the fuel and igniton too!
Old Nov 12, 2002 | 02:56 AM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
john millican modifies the intake so itll fit...and its ALOT cheaper the any tpi parts....the runners are 300 the base is another 350-400...and his intake is 400....trust me the guy knows what hes talking about....
talk to him
Old Nov 12, 2002 | 06:01 PM
Engine: 4.0L
You don't have to do the custom work, I do it for you. It's really just an intake swap after I machine the intake.
Old Nov 12, 2002 | 07:45 PM
Vader's Avatar
If you decide NOT to go with the LT1 intake for now, you can get some benefits by porting the intake plenum, at least behind the throttle body.
Jake_92RS
Jan 28, 2020 10:37 PM
Fast355
Dec 2, 2016 06:33 PM
gta90
Sep 15, 2015 04:00 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
