Some questions I needed answered....
Old Nov 13, 2002 | 12:00 AM
beamar's Avatar
Almost done putting my motor back together, there is a few things I need to know.
I have Headmen headers and Y-Pipe, Which don't have a spot for a 0/2 sensor. I'm going to drill holes in the Y-pipe and weld on a nut so I can use my 0/2 sensors. My question is, which size is the 0/2 sensors?
I'm running a hooley 670, But it's a diff model, it has no IAC. The path is casted into the metal, but no hole to srcew a sensor is there. I'm going to have it drilled and tap so I can put the stock one in, anyone know the size of the thread?
Will a holley 670 accept the stock TPS off my stock TBI unit?
When I'm bolting back on my new heads, what should I use on the threads?
I put some cam and lifter break in oil on the lifters and cam before I put them in. Do I use the rest of the bottle I have and put it in with the oil?
Do I need to do anything special besides the break in oil for the new cam and lifters? How long do I need to run the breakin oil?
thats about it for now....
Old Nov 13, 2002 | 12:25 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You can't really use that carb with the computer. Forget about using the computer, get a non-computer controlled distributor and you won't need to worry about any sensors.
Old Nov 13, 2002 | 12:32 AM
beamar's Avatar
This is a 305 TBI motor. 91 Camaro RS. I have a Holley 670 TBI unit...
Old Nov 13, 2002 | 01:00 AM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
the jegs weld in O2 bung is 18 mm
Old Nov 13, 2002 | 10:15 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Oops
I need to stop reading the board before I go to bed.
MustangBeater20
Oct 29, 2022 09:20 PM
IROCZ1989
Jan 24, 2016 03:55 PM
redmaroz
Aug 16, 2015 11:40 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
