soaking lifters
Old Nov 17, 2002 | 06:21 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
soaking lifters
i got a cheap set of elgin hydraulic lifters. should i soak em before setting the valves. the old edelbrock ones said not to but i dont know. they easily push in unlike the old edelbrock ones. thanks
Old Nov 17, 2002 | 06:24 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'd soak them in some tranny fluid overnite.
Old Nov 17, 2002 | 06:43 PM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Soak them in Oil and get it all set up set the valves......then once the motor has got good and warm....go back and set them again. I used new roller and knew I had them set correctly but after I ran it about 20 min. I needed to reset them. 2 turned up too tight.
Brian
Old Nov 17, 2002 | 06:58 PM
Marshall89ws6's Avatar
i wouldnt put a cheap set of lifters in nehow.... if you cant trust em ...... dont do it...... u could break a lot of things like that...... just be careful what u use in your engine/investment, and yea i would soak em ..... A LOT. in oil or cam lube overnight.
Old Nov 17, 2002 | 07:06 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
For my new motor, I didn't soak my lifters. Instead, I just primed the heck out of the oil pump right before adjusting the rockers. Primed it until I had oil coming out of the rockers. It must have worked, cuz the rockers are adjusted perfect, never had to readjust after getting the car running.
Old Nov 17, 2002 | 07:53 PM
ede's Avatar
ede
i usually put them in a can of oil and push the plunger down with a push rod. i doubt if you'd hurt anything if you didn't soak them or preoil them
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
skinny z
Oct 5, 2015 06:23 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dimented24x7
Sep 6, 2015 03:51 PM
