Need recoms for 395 SBC buildup.
Old Nov 21, 2002 | 03:31 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I already have purchased a 4 bolt block for my project.
I'm interested in biulding a 395 as opposed to a 383.
What would be a good rotating assembly for this project?
Crank? Rods? Pistons?
What should I be very careful about or aware of?
Any comments would be appreciated.
TIA
Doc
Old Nov 21, 2002 | 05:55 PM
Fast3rdGen's Avatar
from what i hear unless you plan on blowing it or puttin a turbo on it, 396 sbc's aren't worth the extra cost. they cost more than a 383 and with the same parts (compression, heads, cam, induction) you gain almost zilch in HP and TQ. but just what i heard so i dunno for sure. i'd go for a stout 383.
Old Nov 21, 2002 | 06:09 PM
Dustin Mustangs's Avatar
Car: I
Engine: Taunt
Transmission: Mustangs
I assume you're aware of this already but maybe not. GMHTP (the magizine) has a fuel injected 396 in there magnum tpi project car ('87 firebird I think) right now. Unfourtunatly they are having some trouble with it, but maybe you can still get some ideas from them. Do a search for 'magnum tpi' and you should find a buch of posts.
Old Nov 21, 2002 | 07:04 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
I've been following the Magnum TPI project car in GMHTP.
It seems like their main problem now is getting enough air into the engine.
Old Nov 22, 2002 | 07:31 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
why would there be that much airflow difference with a 383?
Piston selection is less. Rod ratio is more compromised. Not to mention additional clearancing required.
Torque increase is minimal. Go with a 400 or a 383.
gixxer92
May 18, 2017 11:20 AM
darwinprice
17
Oct 11, 2015 11:51 PM
92rsvortec350
19
Oct 9, 2015 09:39 AM
Bradsaundry
Oct 7, 2015 04:35 PM
Damon
Sep 26, 2015 04:29 PM
