Why is my TBI hard to start when very cold?
Old Nov 25, 2002 | 08:22 PM
raggedout91RS's Avatar
Car: '84 Z28
Engine: Goodwrench 350
Axle/Gears: good guess
I have a 91 RS. It is a bone stock LO3 besides open element conversion and has 200,000 miles on it. The car runs great and has never gave me much of a problem until recently. When I go to crank it in the morning it will run for like a split second and then die, and then after about three trys of turning it over it will run but badly and eventually clear up in about 10 seconds. It is about 30 to 40 degrees in the morning here right now.
Old Nov 26, 2002 | 07:06 AM
camaro6spd's Avatar
isn't there a like...umm..air heater thing, basically it pulls air from around the manifolds when it is cold out so it get warm air to start with. i don't know how fast the manifolds heat up but if you have that open element that would have by passed it....i dunno i am a TPI man.
Old Nov 26, 2002 | 07:44 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
i think (not 100% sure) that our cars wait for oil pressure to register before they allow the ignition to spark... this (i think) is to keep wear and tear after startup way down. i know my tbi stock setup takes like 3 seconds before it fires in the morning.
Old Nov 26, 2002 | 07:55 AM
TBI305Camaro's Avatar
20 degrees in the mornings here and my carb starts no problem...
Last winter when I had my lo3 with TBI there was a few morning when it wouldnt start...we are talking in the single digits tho...30-40 degrees I never had a problem. I had the open element to.
92camaroJoe
Jul 29, 2023 07:57 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
92camaroJoe
Aug 13, 2015 06:07 AM
drathaar907
Aug 6, 2015 04:20 PM
