How much metal is too much?
Old Nov 30, 2002 | 04:53 PM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
I just got my 91 Z put back together. It has a 8000 mile zz4 engine. I put in new bearings, rings, and redid the heads. I got ALOT of metal in the oil only after 15 min of driving. Now how much metal in the oil is normal?
Old Nov 30, 2002 | 07:51 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Not to sound rude, but....Daaaa!! NO! metal in the oil is normal.. Seriously though. Not a good sign!!!
Keiran
Old Nov 30, 2002 | 08:03 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
only had small ammounts of metal in the oil in my engine after break in and the metal was in particle form to give you some idea. if the oil looks like silver spray paint then you probably made a mistake somewhere with the clearences or the re-assy. of the motor.
Old Dec 1, 2002 | 03:35 AM
radiateu2's Avatar
metal in oil
did you blowout the heads when you finished grinding on them? Any machine work been done? Most likely bad bearing clearances as mentioned.
Old Dec 1, 2002 | 08:52 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Any at all is too much. None whatsoever is normal. Whatever is shedding enough metal to be visible, isn't destined for this world very long.
What is it? Steel, cast iron, aluminum, copper? That's a good clue as to what it is.
MrPackstin
Oct 25, 2017 08:09 PM
Night rider327
Feb 25, 2016 09:50 AM
bigjay89gta
Oct 15, 2015 08:04 AM
Numbah-1
Oct 2, 2015 08:27 AM
sjorgens
Oct 1, 2015 07:54 PM
