WHERES the The fuel pump relay FOund?!
Old Dec 1, 2002 | 06:41 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
Yo guys im looking for the FUEL PUMP RELAY
Q: Why is my car getting harder to start day by day?
A: Before you go spending big bucks on a new starter or fuel pump. Check the The fuel pump relay. It could be dying and you might be able to save a large sum of money. On most F-Bodies these relays are located in the extreme rear-driver's side corner of the engine compartment behind the brake booster.
UM can someone give me a picture?
something?
HOw do I test it?
I need more info!
Old Dec 1, 2002 | 07:26 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Dave, you've been given the location...it'll be a "box" looking thing, have clips on either side, then 4 or 5 wire-square connector plugged into it.
If you do a search here, on the TBI and TPI boards, you'll most definitely find the pinouts for testing.
If for some odd reason your search results come up negative, post again and I'll dig the pinouts out for you.
Old Dec 1, 2002 | 08:22 PM
Diggler86's Avatar
Car: 86 TA
Transmission: 700R4 - 2200 stall
Axle/Gears: 3.42 posi
mine was the front most one of the group of relays and had a rubber thing that attaced it to a post.
Old Dec 1, 2002 | 08:31 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
Well ive been looking around and searching
but nothing really hits the spot.
I want to know if this is the problem my car is having!
Becuase I dont want to go threw all that "fuel pump" changing its a pain.
Old Dec 1, 2002 | 09:09 PM
Diggler86's Avatar
Car: 86 TA
look at thsi thread for a pic:
https://www.thirdgen.org/techbb2/sho...hreadid=135707
Old Dec 1, 2002 | 09:34 PM
davecamaro's Avatar
Car: Bonnievillie
Engine: 3.8L
Thanks man!!
Awsome me and my bud are lookin into it now.
I hope its not my pump or else my car will be sitting for ages!
RazorN8
Jan 7, 2022 11:44 AM
89GTAOz
May 16, 2020 09:31 AM
mustangman65_79
Apr 14, 2017 05:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
