Removing mechanical fan for winter
Old Dec 1, 2002 | 06:50 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I just removed for the winter, my thermostatic cluch mechanical fan i was running on my 82 Z28. My car runs so much better. Get gets up to temperature faster and runs at 200 degrees. I now get heat instead of warm. Will this harm anything. It won't be getting over 40 here for a long time and snow is comming.
Old Dec 1, 2002 | 07:09 PM
breathment's Avatar
i would only be worried about the car sitting idle for a long period of time and heating up. but i bet in 40* weather it would take a long time for it to do that. and all u would have to do is get going again. just keep a good eye on the temp..
i got a friend who has a 2001 neon, burned up his fan some how.. wiring caught on fire. suprisingly it happend after he took his car offroading.. and he hasn't had a fan in the past month in a half. no problems yet. just stay out of slow stop and go traffic.
Old Dec 1, 2002 | 07:18 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Ya...you need to have a fan...better alternative would be to use a higher temp Tstat.
I'd put the fan back in and run a 195 Tstat if the heater is the issue. Without a fan during low speeed/no speed, there's no flow across the radiator...temps raise fairly quickly. You could be setting yourself up for some serious wrenching soon
Old Dec 1, 2002 | 07:35 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I had an electric fan on my truck for a couple of years before using it for the race car. In the winter time it never came on unless I was sitting in traffic for a long time.
RazorN8
Jan 7, 2022 11:44 AM
BewleyBizzIROC
Feb 3, 2020 09:52 AM
Vintageracer
Jan 10, 2020 05:33 PM
19irocz85
Aug 26, 2015 07:54 PM
3rdgenparts
Aug 8, 2015 07:09 PM
