Did any of the Computer controlled carb cars come with electric fans
I just basically wondered what I asked. If so would it be possible to make the fans be controlled by the computer at least if I upgraded to the 87 l69 computer(It is now a 350 so I will eventually probably upgrade to that computer so i can use the 350 ho chip.
Ben
Ben
Car: 87 Formula
Engine: 327
My 87 LG4 has an electric fan.. It is not controlled by the computer though.. theres a seperate thermo switch in the passenger head that activates a relay. Stock thermo switch is set for 220. I need to find a lower temp unit myself. Lg4s are single electric fan though.. I beleive tpi motors have 2.
Here is my other thread which is the reason I asked this:
https://www.thirdgen.org/techbb2/sho...hreadid=146909
If you have any insight on it I would appreciate it. And by the way, I know not all tpi cars came with the dual setups either. I have a single setup off of a tpi car and a dual setup off of another tpi setup(this is what I am using). They were both from 305 tpi cars also.
Ben
Ben
86IROC112
Aug 17, 2015 02:00 PM
