Fuel Pump Location
Old Dec 3, 2002 | 07:21 PM
zerotosixtyV8's Avatar
Car: Camaro
Fuel Pump Location
Where exactly is the fuel pump on a 1989 IROC-Z located? I am gonna be doing an engine swap sometime soon and I need to upgrade the fuel pump (as per recommendation, the engine is a 383). I heard that the fuel pump is located in the gas tank, i really hope it's not cause if it is it'd be a pain . How hard is it to replace if it is located in the gas tank?
Old Dec 3, 2002 | 07:32 PM
Steve86TA's Avatar
Car: To many to list
Yep.Its in the tank.Its really not that bad of a job.Take your time and you will be fine.
Old Dec 3, 2002 | 10:47 PM
man_of_steel27's Avatar
Car: 92 RS - For sale
Transmission: 700 R4
Axle/Gears: yup, it has a peg leg
just make it easier on yourself and make sure gas tank is empty because when it is full it is a b!tch to get down (fuel tank)
Old Dec 5, 2002 | 01:05 AM
MdFormula350's Avatar
yup in the tank. took a few hours (at least for me and my grandpop)!
Old Dec 5, 2002 | 12:27 PM
MR. KIDD's Avatar
Car: 85 IROC
Engine: 406
Transmission: A4
Yes its in the tank (fun job) my buddys and myself are running 400s 406s 409s off the stock pump even with the steroids on the 409 no problems.
Old Dec 5, 2002 | 01:43 PM
camaro_1983_383's Avatar
pulling the talnk is the hardest part. the fuel pump will take 3-5 minutes after the tank is down. the part that sucks is that your tank is above your muffler. my 383 is doing just fine though. but if your going from FI to carbed, your in-tank pump will be way to strong and you will need a pressure regulator if you stay with the stock pump. carbed cars only need 5-7 psi. if your engine is carbed, your pump should good. just put a mechanical pump on your engine. holley makes a 7.5 psi pump for 52 bucks in summit. good deal. Part number 12-834. you may be able to see mine on my sig, lower left side, chrome.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
92camaroJoe
Aug 13, 2015 06:07 AM
