non-thirdgen, but a good reminder! (no start)
Old Dec 3, 2002 | 07:33 PM
junkyarddog's Avatar
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
I'm outside in the freezing cold today trying to figure out why my car won't start. It's an '89 corolla by the way. I won't go into detail since it's a different car, but after my fingers were nearly frozen, I discovered a bad ground connection at the engine block on the heavy cable from the battery.
I didn't just come across this by pure wit. I was trying to reach under the intake to get my test leads on the starter motor terminals (rear of engine bay....very cramped) I then discovered a completely melted connector on a very small ground wire between the pass-fender well and the engine. It seemed strange at first because why would the starter and ingnition be pulling current through that little ground wire??
I looked on the other side of the engine (actually the on the transaxle case) and there it was! that nasty corroded wire that I knew I should have replaced while the weather was good. I disconnected it, cleaned with a wire brush and reconnected it, problem solved.
the reason this threw me off was the bizarr symtoms: radiator fan and turn signal & high beam indicators turn on with ignition turned to START, no cranking....I was like WTF
looked at a Hayne's schematic and was still like...
the first thing I checked was the ignition switch. Most people I talked to said it was the likely suspect.
So bottom line: take some time to RE-GROUND the engine block, battery etc. before it has to be done in the freezing cold! It's such a simple and common problem.....remember, current flows from the negative side.
I know that a Toyota is not a thirdgen, but I'd like to point out that I fixed this car for free. If it was thirdgen I would have had to replace something
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
justin57
Aug 20, 2015 07:05 PM
cstrobel65
Aug 15, 2015 10:19 AM
86Base
Aug 8, 2015 01:34 PM
