Can I bypass Oil press./ fuel pump sensor
Old Dec 4, 2002 | 07:44 PM
raggedout91RS's Avatar
Car: '84 Z28
Engine: Goodwrench 350
Axle/Gears: good guess
I would like to bypss that send. unit behind the intake manifold that senses oil pressure and then turns on the fuel pump. Has anyone done this? I have a 91 RS with a LO3.
Thanx, Warren
Old Dec 5, 2002 | 06:39 AM
ede's Avatar
ede
it's above the oil filter, the one on the china wall behind the intake is for the gauge. why would you want to eliminate it, it's there to save your engine if you have problems
Old Dec 5, 2002 | 04:59 PM
long&low's Avatar
Car: 88 ext.longbed 1/2 ton
Engine: TPI 350
Transmission: Slushbox 400
Why would you want to disconnect it?
It supplies power to the pump if the relay goes bad don't it?
Old Dec 5, 2002 | 07:22 PM
Car: '84 Z28
No, it just tells the pump to run when the engine is producing oil pressure. The reason I want to bpass it is because I want to run a Mechanical gauge to check the accuracy of my factory gauge, which I think is way off.
Old Dec 5, 2002 | 07:37 PM
long&low's Avatar
Engine: TPI 350
Yes you can disconnect it but, if the f/p relay shoots craps on you while it is disconnected the car will not start.
But what are the chances of that happening?
Old Dec 6, 2002 | 08:39 AM
ede's Avatar
ede
you're confused. the sender on the china wall is for the gauge, not the sender for the fuel pump, above the oil filter
Old Dec 6, 2002 | 08:51 AM
long&low's Avatar
Engine: TPI 350
It don't really matter where it is located as long as he disconnects the right one to do his test. If he gets the wrong one the first time he crawls back under there and gets to do it over again .
Old Dec 6, 2002 | 01:24 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Why not just run a tee off the existing oil pressure sending unit port? Don't remember the the NPT thread size but it should be easy to find.
Also on my 89, there is no oil pressure sender on the back of my block by the intake...I guess the one above my oil filter doubles as the oil pressure sender/fuel pump power circuit.
But on my sister in law's 86 IROC, she has the oil pressure sender on the back of the block along with the one by the oil filter.
Maybe after 87 or 88 they eliminated the sender at the back of the intake and just ran it off the sender above the oil filter??
Old Dec 6, 2002 | 06:49 PM
Car: '84 Z28
You are right Iroc zz3. There is no send. unit on the back of my block. I thought there was but I guess it must have been one of my other GM v8 rides. I looked the other night and there was just a square headed plug in that place. I guess I'll just run it from there. I replaced my send unit above the oil filter about a year ago and ever since then the pressure reads 60 pounds on freeway and about 35 at idle when Hot. It used to never read that high. Oh yea my car has 200k on it so I know its wrong. Thanx for the replies guys.
Warren Harrell
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
