383 Stroker Kits
Old Dec 11, 2002 | 05:45 PM
2L8ULOZ's Avatar
383 Stroker Kits
What are some of the better(reliable) stroker kits on the market.?What should I look for in a kit? Comments on the kits? Any links to web site would be appreacheated.(sp?)
Old Dec 11, 2002 | 08:04 PM
Roostmeyer's Avatar
Car: 88 Trans Am GTA
Engine: 5.1L Gen III
Axle/Gears: 3.70
http://www.enginekits.com/
is the cheapest and they come ballanced
http://www.summitracing.com
is a good kit i guess for around $1100
http://www.jegs.com
has a "kit" using eagle connecting rods, crank... Not sure but I don't think they come with gaskets, oil pump, etc.
If you have alot of money http://www.thunderracing.com has lunati 6" connecting rod stroker assemblies for around $1800
Oh and in the future USE THE SEARCH BUTTON.
https://www.thirdgen.org/techbb2/search.php
PEACE
Old Dec 11, 2002 | 08:33 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I don't have any personal experience, but I've heard that the Lunati kit's are excellent. I was bidding on one on Ebay a few months ago, and when discussing with several people, I got favorable responses about them.
I'm not at home right now, or I would give you some links from where I was looking into them.
Old Dec 12, 2002 | 01:38 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
I got stroker kit pre-balanced from enginekits.com...
Not a bad kit.
Unfortunately, I was not able to use the "CR-3" rods which are pretty much stock rods that have been re-worked and have ARP bolts.
Problem was getting the necessary clearance for the cam (.530/.560" lift) I was using.
I'm now looking for some H-beams that will not need any clearance work to clear the cam. (There goes the balance work.. )
If I had been able to get my cam in a small base circle version, it might have been ok.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
sleprock
Oct 1, 2015 09:39 AM
buckshot63
Sep 10, 2015 09:15 AM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
