Carb 2.8, 10,000MI running BAD!!
Old Dec 12, 2002 | 07:25 AM
92RSMuscle's Avatar
on my buddys CARB 2.8, there are some problems.
when he starts up the car, sometimes it stauls on him
after he gives it some gas, and it gets warm, when he puts it in drive, and touches the pedal lightly (like trying to go slow) it sometimes stauls on him.
he is also running very rich....here is the real kicker
the engine only has about 10,000 Miles on it.
im thinkin the distributor is messed up, the timing is prolly off and his carb needs to be re-adjusted....
would this be accurate?
if not, what else could it be?
mike
Old Dec 12, 2002 | 08:20 AM
Vader's Avatar
Timing probably won't have that much of an effect on the mixture. If your "nose sensor" tells you that it's running rich, no amount of timing adjustment is going to fix that.
Old Dec 12, 2002 | 09:26 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
I smell a carb problem.
FYI, I had one of those carbs (VaraJet E2SE) and found them to be one of the most tempermental pieces of **** I'd ever worked on.
YMMV, of course.
Old Dec 12, 2002 | 10:37 AM
92RSMuscle's Avatar
thanks guys...yea i thought it was a carb problem...
im gonna propose this....ill let ya know what happens
Old Dec 12, 2002 | 11:06 AM
99Hawk120's Avatar
You ought to do something I always wanted to try, which is to put a 4bbl on it. It works on the 3.8L, but I'm not sure if the 2.8 isn't too small for it to do any good...
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
86IROC112
Aug 17, 2015 02:00 PM
