Miles or kilometers???
Car: 86 T/A
Engine: ZZ383
Transmission: TH700R4 Raptor
Axle/Gears: 2,7x -> 3.00 or 3.50
I was wondering if the meter to count how much my 1986 T/A has been driven measures miles or kilometers.
I am almost certain it measures miles in my T/A (was imported from USA, built in Norwood-Ohio)) but would like to know for sure.
Thanks,
Nonni
Thanks,
Nonni
Car: 89 IrocZ
Engine: L98-ish
I couldn't say for sure, but if the car is running, you can always check the odometer against some known distance, either in KM's or miles, and compare.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
It should say right on the speedo. Under the odometer it should say kms if it measures kilometers.
The speedo numbers will be what the odometer calculates. If the speedo is in miles and kms then the larger numbers are the odometer's calculations.
Car: 86 T/A
Engine: ZZ383
Thanks for the info, the larger numbers are miles and smaller are kilometers. So it measures miles
Nonni
Nonni
dbrochard
Oct 3, 2015 12:43 PM
84 TA NV
Sep 6, 2015 08:02 PM
