what is BMEP
Old Dec 18, 2002 | 09:46 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
what is BMEP
and how does it affect performance and all that shiz
Old Dec 18, 2002 | 11:02 PM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
Brake Mean Effective Pressure. I dunno how it translates into performance.
If you use desk top dyno, that's all the program really does is figure BMEP and IMEP (Indicated Mean Effective Pressure).
Old Dec 18, 2002 | 11:41 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Basicly if you spin a motor without it running and measured
the air pressure in the cylinders at different rpms thru the usable rpm range and graphed the results, the shape of the curve
would closely follow the torque curve of the running motor.
Up to the octane limit of the fuel used, the more air you can trap in the motor, the more power it will make. If you know the pressure (BMEP) and temperture of the air, you can calculate the
volume and density and predict power output.
Old Dec 19, 2002 | 12:06 AM
FJK's Avatar
FJK
Yes, BMEP means brake mean effective pressure. Its formula is
BMEP = (HorsepowerX 792000) / (Engine displacement X RPM)
It has nothing to do with the average cylinder pressure within the cylinder. Rather, it provides method, numericaly, to describe & compare the specific power output of an engine at given displacement and engine speed. These comparisons can be done either with a given engine displacement along its operating speed range, or by comparing 2 different engine displacements at a constant or variable speed condition.
For example:
300 BHP @ 5000 rpm 350 CID = 135 BMEP
300 BHP @ 5000 rpm 400 CID = 118 BMEP
The 400 CID engine has lower bmep, indicating the stress levels all the compoents ( block, head , pistons, etc) see are lower relative to the 350CID engine, most other things being held constant. On the other hand, you could say the 350 is running at a higher potential performance level than the 400.
Try different examples of bhp, cid, & rpm and it allows you to understand performace potential & relative stress levels of different combinations. Allows engine designers to understand where they were and where they are going, & the price they are going to pay for a different design.
Regards, FJK
