383 rod balancing problem HELP ASAP!!!
Old Dec 21, 2002 | 12:25 PM
quick_90's Avatar
ok i got a call from the motor shop saying that they couldn't balance the rods with the pistons on ( i had them put on awhile ago) i dont know if this is true or not but thats not the point he went on further to say that it wasnt good to pull the pistons off the rods and then put them back on. is this not good for the rod or is he lying??
please help ASAP
Old Dec 21, 2002 | 12:49 PM
Vader's Avatar
If they're using a rod oven correctly, pressing the pins out and re-using them shouldn't be a major issue. If they're pressing them out without heating, the pins could be scuffed, but with proper heat there should be no galling, material pickup, or other damage to either the pins or rods.
What crank are you running in your stroker?
Old Dec 21, 2002 | 12:56 PM
quick_90's Avatar
I'm running power house kit.
Thanx for the help
Old Dec 21, 2002 | 01:01 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Since it's pretty hard to heat the rod without heating the pin after they're assembled, it's very difficult to get pins out of a set of rods without damaging at least one. And if you damage one, you might as well replace them all, since for the engine to be balanced, they all have to weigh the same.
Get a new set of lightweight pins to put them back together with.
Old Dec 22, 2002 | 05:14 PM
Vader's Avatar
A Thermos full of liquid nitrogen is cool to have (in more ways than one). It works great for bearing outer race removal - not in engines, of course.
Reborn756
Sep 4, 2015 03:42 AM
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
sreZ28
Aug 14, 2015 07:48 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
