Thrust bearing clearance?
Old Dec 23, 2002 | 12:52 AM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
I am kind of confused on how to measure thrust bearing clearance. So if you can get your .0025 clearance on the thrust bearing but you cannot get your .0030-.010 then you have to sand away the thrust bearing right? now do you measure your clearance with the crank pryed all the way forward? Books are kind of vague.
Old Dec 23, 2002 | 05:53 AM
ede's Avatar
ede
no manual here at work but i believe the thrust clearance is more in the .015 to .020 range, lot more than you said. put an indicator on the crank snout where the dampner goes and the crank rearward and zero the indicator then pry the crank forward and note the reading. i guess you could do it with feeler gage too, but i never have.
Old Dec 23, 2002 | 06:06 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
You're not ever supposed to sand on a bearing, not for any reason.
To measure thrust clearance, pry the crank all the way forward, then all the way rearward. The thrust clearance is how far the crank moves. .015" is typical for a new crank, .020" or more is typical for a reground one.
See your other post for more info.
Old Dec 23, 2002 | 08:03 AM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
what i meant by sanding is the thrust surface not the bearing surface that mates with the crank and yes you can do that. But I found my problem it is in the post of squealing. Very interesting. Thanks.
91 SrS
Oct 7, 2015 04:32 PM
gord327
Oct 3, 2015 01:25 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
mfp189
Sep 27, 2015 09:25 AM
