Clunk sound when braking?
Old Dec 31, 2002 | 05:54 PM
Dolph88sc350TPI's Avatar
Car: 88 Camaro SC, 86 T/A, 92 Eclipse
When I brake I get a clunk sound from the front passenger side I think, anyone have an idea as to what that could be.
Also, is there a way to change motor mounts without pulling the engine or trans?
Old Dec 31, 2002 | 08:33 PM
demonchild's Avatar
the clunk sound is probably something brokem, like a bushing. There is little rubber parts behind the brake that are used for turning. if one of these is broken then you will probably get a clunk, or when it happened to me...it felt like a bump in the road. As for the engine... engine and tranny mounts are to easy to replace. All that yo need is a a jack, 2 jack stand, and new mounts. Jack up the car and then put the jack stands under the suspension to keep the car in the air. after that LOOSEN the bolts that hold the engine to the body. Jack up the engine and inch or two and then take the bolts off of the mount. put the new mount in and torque to specs. be damn careful not to bend the oil pan. You also should read somemore before you attempt this. A chiltons manuel is always a good start.
Old Dec 31, 2002 | 08:34 PM
89 RS vortec 35's Avatar
It could be a broken tork arm mount, mine just brole a couple days ago and it made a clunk whenever I hit the brakes or gas it it is right under the passenger side.
Old Dec 31, 2002 | 09:16 PM
thanks, demonchild and 89 RS vortec 35.
are there any clearance issues when jacking the engine up a few inches?
Old Jan 1, 2003 | 12:46 AM
Bristol's Avatar
Car: 1991 Z28 1LE
Engine: 355 CID HSR
Axle/Gears: 3.23 for now
If its an auto undo the tranny mount....
Old Jan 1, 2003 | 09:40 AM
demonchild's Avatar
well at least everything that everyone told you to do is the easiest stuff to do on our cars.
Frozer!!!
Jan 19, 2024 04:55 PM
ron reece
Southern California Area
Oct 7, 2015 01:11 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
BlackBoulder
Aug 11, 2015 11:15 PM
MENINBLK
Aug 5, 2015 11:58 PM
