IROC guages into '83
Old Jan 7, 2003 | 07:12 PM
madmathew's Avatar
I have an IROC I'm parting out and I want to put the guages in my '83 to replace the crap that it came with. The '83 has the standard guages(speedo and fuel), what do I need to make the IROC guages work? I'm adding the tach, charge, temp, and oil pres. along with it having the 145mph speedo to replace the 85mph one the car came with.
Old Jan 7, 2003 | 07:31 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The cluster swaps right in, you don't have to do anything to the speedo... you'll need an oil pressure sending unit instead of the switch, same for temp; not sure about the tach (whether the wiring is in the non-gauge harness for it).
Old Jan 8, 2003 | 09:28 AM
madmathew's Avatar
Thanks, that makes sense. I might have to run a wire from the coil to get the tach working.
Old Jan 8, 2003 | 10:21 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Take a look at the wires going to your distributor cap. If there is a tach wire next to the power wire, then it should be already wired and ready to go.
Ghettobird52
Jul 5, 2024 11:18 PM
BAMiller
Sep 14, 2015 06:38 PM
g.l.mos
Aug 22, 2015 12:02 AM
355sbcTPI
Aug 19, 2015 04:38 PM
mustangman65_79
Aug 11, 2015 03:17 PM
