real quick help please
Old Jan 9, 2003 | 10:34 PM
IROC of 88's Avatar
Car: 1988 IROC
Engine: See Signature
Transmission: B&M 700r4
I need to know the differences and pros/cons between a hydraulic Roller and a Hydraulic Flat Tappet cam. Also is a stock L98 engine(350tpi) is originally equipped with a Hydraulic Roller.
thanks alot for a fast response
Old Jan 10, 2003 | 08:47 AM
kevinc's Avatar
Car: 1982 Z28
Hydraulic roller has a roller following the cam lobe, flat tappet has a flat (slightly tapered on some designs) surface following the cam lobe.
Advantages of a roller design is less operating friction, and ability to design steeper lobes for faster lifting and closing of the valve.
Advantage of flat tappet is cheaper manufacturing cost, and therefore lower prices.
Assuming the L98 you're asking about is an '87 or newer, it came from the factory with hydraulic roller cam/lifters.
Old Jan 10, 2003 | 09:15 AM
IROC of 88's Avatar
Car: 1988 IROC
thank you very much....
Pac J
May 17, 2020 10:44 AM
mattcanty
Oct 12, 2015 11:08 AM
racereese
Oct 3, 2015 03:46 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
