timing cover
Old Jan 11, 2003 | 11:35 AM
Electron_Blue's Avatar
Car: 83 Camaro
Transmission: th350
timing cover
hey buys...are there any tricks toputting on the timing cover...the rubber dealy at the bottom and stuff...its a pain in the **** and the bottom wouldnt go in...so we just started tightening bolts figuring it would go in but it hasnt....we got all the bolts in except the bottom 1 on each side...help?!?
Old Jan 11, 2003 | 11:38 AM
Car: 83 Camaro
Transmission: th350
omg i just had a breakthrough...would it work easier if i loosened some oil pan bolts?
Old Jan 11, 2003 | 12:03 PM
ede's Avatar
ede
yeah loosen the oil pan or trin the inner lip a little on the timing cover, or do both
Old Jan 11, 2003 | 08:29 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
yea, what ede said... that works... that was a pain for me, too, til someone told me the same. that lip that holds that seal needs to be trimmed back about a half inch on both ends. tin snips will do it, just make sure you file the rough edges down so as not to cause the seal any premature grief (wear).
KAM
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
I'llrocya
Feb 2, 2016 11:43 PM
NBrehm
Aug 25, 2015 11:49 PM
