Cylinder Heads?
Cylinder Heads?
Which do you guys think would be better for a 305 LG4 with 9.6:1 compression, and a Comp Cams Extreme energy cam:
int exh
Gross Valve Lift: .495 .502
Duration: 270 276
Duration @ .50 218 224
110 Degrees of Lobe seperation.
World Castings S/R Torquer Heads
or
Chevy truck L31 Vortec cast iron heads, GM P/N 12558060?
int exh
Duration: 270 276
or
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Check this link for more info on your existing LG4 416 castings:
https://www.thirdgen.org/techbb2/sho...hreadid=150604
They are good heads from what I understand, and have great potential with some porting/polishing effort. Also check Sitting Bull's sig - he has a link in his sig on porting heads.
I have a set of the 416 heads from an LG4, and after reviewing the how-to's, and looking at the heads and how little has to be done with them, I'm going to port mine myself to put on my 305, and I've never done it before.
Also check out the how-to at
http://www.sa-motorsports.com/diyport.htm
$40 for the porting kit, $40 for an electric grinder, and some brow sweat may save you a ton of cash for other things.
Chuck84TA
Jul 15, 2016 09:05 PM
NinjaNife
Aug 23, 2015 11:49 AM
