I need a carb intake expert!! (1987 lg4 vs older small blocks)
Old Jan 13, 2003 | 03:42 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
I heard that my intake (LG4 305 1987 Camaro Iroc) is different then all or most of the other small block intakes,,,because of bolt holes or something,,,does anyone have any pics or can explain whats the deal??? I would like to be able to pic up an intake some were and know the difference by just looking at it! Thanks
Old Jan 13, 2003 | 05:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The center two bolts one each side of the intake, that bolt the intake to the heads, are at a different angle than the other bolts. This makes it a little easier to torque those bolts.
You can use the older style intake by elongating those holes so the bolts will fit into the heads.
If you PM Vader, he'll probably even post some pictures.
Old Jan 14, 2003 | 11:18 AM
Vader's Avatar
5-7 has you covered. Beginning with the 1987 model year, SBC heads had the center two intake bolts canted upward. The holes were drilled and tapped at 72° from the intake flange instead of being perpendicular (90°) like in years past. The only exception to this was on the Corvette aluminum heads, which retained the 90° bolt holes in those two positions. That means that with stock iron heads, ant '87-later intake should bolt right up. You can use an early design intake if you elongate the center two holes and either machine the base at an 18° angle of use tapered structural washers to bear the bolt load at the correct angle. Tapered washers like this are available at any place that sells structural fasteners for construction steelwork. They are square and may require soem trimming, but the common flange angle on structural 'H' beams is 15°, so with only a little grinding or filing, you can make them fit perfectly.
The remainder of the bolt holes and ports are in the same positions as the older design, so you should have no problems. Again, the exception is the Corvette heads/intakes, which don't have the integral exhaust port and canted center bolts.
Old Jan 14, 2003 | 12:40 PM
laiky's Avatar
i think holley sells something like that for use with the stealth ram
jhawkeye
May 25, 2022 06:33 PM
9192camaro
16
Feb 3, 2019 12:21 AM
theshackle
Mar 5, 2017 06:37 PM
Fast355
Dec 2, 2016 06:33 PM
camaro71633
Sep 1, 2015 10:24 AM
