odd sound with.. suspension?
Old Jan 16, 2003 | 01:21 AM
novafyre's Avatar
Hello, I have a 1984 pontiac firebird. It drives well, but the problem is there is a 'clunking' noise whenever hitting a bump. You can feel it too. It has new shocks in it, and I checked those and they were in tight. The sound usually sounds like it's coming from the right rear. My friend said it could be the rear-end, but I'm not certain. The car does not have a posi-track rear end, but it squeels the tires on the right rear, so I don't know if that's what it is.
What do you think?
Old Jan 16, 2003 | 05:37 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Possible causes: Upper shock mount broken out of the body (very very common, first thing to checks, pull up the carpet behind the back seat to see it); loose bracket for stabilizer bar end link; bad control arm bushings.
J-money
Jan 4, 2019 09:45 AM
Stryker412
Sep 20, 2015 06:59 PM
Lanz06
Sep 14, 2015 07:16 PM
84 TA NV
Sep 6, 2015 08:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
