with the right programing, can I run vortec heads W/O the EGR
Old Jan 18, 2003 | 10:14 PM
BOTTLEDZ28's Avatar
Transmission: A4
I am looking into the SDPC vortec TPI setup and it says it requires the use of the EGR kit. I do not want to cut a hole in my nice SLP headers for a stupid EGR valve. So can I sucessfully run these heads on my tpi engine, get the computer reprogrammed and not have any drivibility problems..... I know I need the base too
Old Jan 19, 2003 | 08:50 AM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
yes you can but, as you know it is not going to pass a smog test
Old Jan 19, 2003 | 10:12 AM
ctandc's Avatar
Yes, and like mentioned, the only real consideration is whether or not you have to pass a visual smog test.
You can just burn your own chip, or have someone do it, and they can turn the EGR OFF in the chip parameters.
HTH
Old Jan 19, 2003 | 12:05 PM
BOTTLEDZ28's Avatar
Transmission: A4
well here in Mass, there do check the smog stuff but mainly the cats only. it depends where you go. I have a few hook ups that canget me a sticker too. I just want to get rid of all un needed stuff under the hood
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
