Power steering pump broken ?
Old Jan 19, 2003 | 08:27 AM
lordfinesse's Avatar
Hi,
first, sorry for my bad english, but iīm from germany, an the mechanics there donīt know anything about this camaro.
Iīve got an Camaro RS V6, 189cui.
My Problem is my power-steering; after an "burnout-session" (Donutīs... ) with also fully turned steering wheel. since that, my power steering does not work correctly .
with higher rpmīs (over 1800 rpmīs), she works very alright. with lower rpmīs itīs not function it any longer.
The power steering fluid is full. It doesnt leak.
Would I be correct by saying the power steering pump is broke?
...and is this easy to change ? (servo-pump with storage vessel kosts about 90,-€)
Old Jan 19, 2003 | 08:40 AM
todd200's Avatar
Car: 87 IROC-Z
Engine: 350ci
They are not hard to replace. See if you can find a manual online somwhere. I prefer Chiltons manuals. I you can't its pretty simple to change, more so if it comes with the resivour-sp? Just remove the hoses from the pump, remove the belt or belts, and unbolt it. Bolt the new one on, and re-install the belts and hoses. Fill it up to the full mark and turn the wheel all the way to each side about 20 times with the car off. Check the fluid and fill it back up to the full mark. Then start the car and turn the wheel another 20 times. Top off the fluid and your done. Good luck!
Old Jan 19, 2003 | 09:26 AM
Seems to be pretty simple to change, but i hope it is only the pump, and no other thing whereīs broken...
Old Jan 19, 2003 | 11:21 AM
Vader's Avatar
Finesse,
I'm sorry for my bad english, but I'm from the US.
There are only two hose connections to the pump and four fasteners holding the pump in place. They are easy to replace, but it will take a little time.
The steering assist system is simple, and the gearbox is very rugged. It is likely that you only damaged the pump, and a replacement should solve the problem. My guess is that the higher RPM did some damage to the vanes in the pump. The pump would be making maximum pressure when the steering wheel was held against the stop, and the higher pressure might have been too much for it. The pumps will normally withstand that kind of use unless they are already worn.
These pumps are very common in the US, both new and rebuilt. The rebuilt pumps are selling for around $62US (58EUR / 114 DM) and are readily available. That includes a $15 (30DM) core charge that is refunded when the old pump is returned.
Old Jan 19, 2003 | 11:28 AM
Allright, thanks to you :hail: , i think i will order a new pump in the next days!
Frozer!!!
Jan 19, 2024 04:55 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
