How to change Belt
Old Jan 25, 2003 | 02:50 PM
tamonez's Avatar
Car: 88 Iroc
Transmission: 5 speed
How to change Belt
I'm outside now trying to change my water pump but I cant get of the belt. The manual says use a 15mm socket to relieve the "belt tensioner" but there is no place on the tensioner to fit a 15mm socket. please help!!
G:rockon: Raiders
Old Jan 25, 2003 | 02:52 PM
87LB9B4Z's Avatar
Car: See ID
Engine: See ID
Transmission: M39
I beleive you put the socket on the bolt that holds the tensioner wheel to the tenstioner - and pull with a breaker bar...
Old Jan 25, 2003 | 03:43 PM
patrickm00's Avatar
the belt tensioner is on cars with the single serpentine belt. it's usually somewhere near the top left, and looks like a 3" diamter aluminum cylinder with a round protrusion w/ a 1/2" square cut out of the middle. that's where you put the breaker bar, (and pull to the passenger side if i recall). anyway, if you have multiple belts, there's some sequence of parts you have to loosen to get the water pump belt off. i think in general, the alternator is the 'tensioner' that you tighten up last, so that might be the place to start.
Old Jan 25, 2003 | 04:34 PM
87LB9B4Z's Avatar
Car: See ID
Engine: See ID
Transmission: M39
Oops. I don't have the single serpentine belt but my other vehicles do and they require a 15 mm socket on the bolt that holds the tensioner wheel to the tensioner. I do recall a half inch drive square in the tensioner on a friends newer Firebird.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
mustangdmurder
Aug 21, 2015 07:17 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
scottmoyer
Aug 9, 2015 10:18 PM
