bolt size? and bad oil leak
Old Feb 2, 2003 | 11:14 PM
ChevyGuy87's Avatar
Car: 2004 Wrangler Rubicon
Engine: 4.0
Transmission: NV3550
Axle/Gears: Dana 44s with 4.10 and air lockers
i got a really quick question. does anyone know what size the bolts are for the flywheel inspection plate on a T5? i lost mine when i was building my engine, and sorta used zipties for a while (i know, i know, *cough* HACKER *cough*). but since i just finished doing my clutch and my car will be on jackstands till the weather clears up, i want to make sure everything is done the right way.
also, i've had a bad oil leak since i took my intake manifold off. i think it might be the rear china wall gasket, but i want to make sure before i take all that stuff off again. it doesn't leak at idle when stationary, but everything under the car is covered in oil, and if i drive on wet roads, you can follow the pretty colored trail for miles. i just had the tranny out so i know it isn't the rear main seal, replaced the oil pressure sending unit, dist. is clamped down tight. sound like the china wall gasket?
Old Feb 3, 2003 | 07:17 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The bolt size is 6mm I think... they're the standard metric size that uses a 10mm head, whichever size that is.
Did you by any chance remove your smog pump at the same time you removed your intake? I assume you put the intake back.... but is the smog pump still gone?
Old Feb 3, 2003 | 10:33 AM
ChevyGuy87's Avatar
Engine: 4.0
thanks for that bolt size!
about that smog pump, the car used to belong to my friend before i knew him. they put a 350 in and ripped all of the smog stuff out. i've never even seen it in the car. why do you ask?
Old Feb 3, 2003 | 10:55 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
How did I ever guess?
https://www.thirdgen.org/techbb2/sho...hreadid=158139
Go down to my second reply, about halfway down. I post this all the time, it's amazingly common... I wonder sometimes how much extra profit the oil companies have made from that one bolt hole.
Old Feb 3, 2003 | 01:07 PM
ChevyGuy87's Avatar
Engine: 4.0
originally, that's what i thought my problem was. but i sealed up the bolt hole, and the problem still persists
89GTAOz
May 16, 2020 09:31 AM
MoJoe
Fabrication
Aug 19, 2017 07:12 PM
Navy8125
Aug 21, 2015 09:32 AM
knight72
Aug 10, 2015 09:32 PM
drathaar907
Aug 6, 2015 04:20 PM
