A/C Compressor Noise, help!
Old Feb 3, 2003 | 11:16 PM
92GTA's Avatar
First off, my A/C works perfectly. When it runs there is no noise whatsoever. When I bought the car 3 years ago, I had the A/C system completely gone through, it didn't need freeon then nor has it needed anything in the last 3 years, I have it checked every spring.
Now, when my car is idling, every 5-10 seconds the A/C compressor makes a little noise that sounds like a little racoon under the hood. You can barely hear it with the hood closed but it bugs the hell out of me. It only happens when the A/C is NOT on. It's been doing this for almost a year. I don't really have the money to have it checked this year but if it's a problem that needs to be checked out so it doesn't cause any damage, I want to go in knowing what it is so I don't get screwed.
Any ideas what the heck it is?
Old Feb 4, 2003 | 09:45 AM
Vader's Avatar
Sounds like the clutch idler bearing may be failing. You can replace the clutch without removing the compressor or evacuating the system on most Harrison/Frigidaire compressors.
Old Feb 4, 2003 | 12:22 PM
92GTA's Avatar
Awesome, that's great news if that's all it is!
Thanks! I'll have it fixed right away.
Old Feb 6, 2003 | 01:18 PM
92GTA's Avatar
Well an A/C shop wanted $120 so I bought the bearing for $26 and I'm going to install it myself...
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
