What did I just break (Picture)
Old Mar 24, 2003 | 10:32 PM
  #51
Mutiny32's Avatar
Car: 1992 Camaro RS, Teal
Engine: 305 TBI, Soon to be 383 HSR
Transmission: Pro-Built 700R4
It's the fan switch. I broke the EXACT same connector right below the #8 cylinder when changing headers. Now all I need to figure out is where to buy a new connector. I've been running all winter without a fan switch.
Old Mar 24, 2003 | 10:38 PM
  #52
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
-The O2 sensor is on the exhaust (drivers side).
-The Fan switch is between the #6-8 cylinders in the head.
-The temp gauge sensor in between the #1-3 cylinders in the head.
-The knock sensor in on the at the bottom passenger side of the block.
Take your pick of which one it is... I know were all of these are because i have installed all of these at least once before.
Old Mar 24, 2003 | 10:39 PM
  #53
rezinn's Avatar
Come on guys, let it die. We know where things are and we know what he broke.
Old Mar 25, 2003 | 12:27 AM
  #54
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Is it the Cold Start Switch?
Old Mar 25, 2003 | 07:22 PM
  #55
Mutiny32's Avatar
one last post. I have proof but no camera. Went and bought the connector today. Fan switch plug.
Old Mar 25, 2003 | 08:51 PM
  #56
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
It is NOT the O2 sensor!!!!!!!!!!!!!!! The O2 sensor (on my '87 IROCZ) is on the driver side screwed into the exhaust manifold.
The sensor in your held is a temp sensor. Just start your car and see what does not register on the dash board.
If its the secondary fan temp switch, it will not show on the dash.
Old Mar 25, 2003 | 09:23 PM
  #57
camaroguy2003's Avatar
Car: 1992 Camaro RS
Engine: 406 SB
Transmission: TH350
It's the coolant temp sender for the dash, I broke that off when I installed my headers and had to replace it.
tonys91rs
Oct 10, 2015 03:31 PM
88HARDTOPIROCZ
Sep 18, 2015 10:30 PM
snakeshooter
Sep 7, 2015 11:13 AM
Strick1
Sep 6, 2015 02:21 PM
Ian Irvine
Sep 4, 2015 08:08 AM
