this is very weird......
Old Feb 9, 2003 | 09:30 PM
sublime7880's Avatar
im rebuilding my lo3. when i went to auto zone to buy a replacment timing set they gave me one that did not fit. the cam gear was to big for my cam (the three holes looked like it was for a bigger cam) i returened it and bought a new one from oriely. same thing!!! the guy tore open every set for camaros a found the right one. the book said however it was for a v-6 camaro. is this a mistake in there books? or is my engine not a lo3? (yes im sure its a v8)
Old Feb 10, 2003 | 12:00 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
if the cam is for a small block chevy it should work. do u have a book or something to help u along with the buildup? might be a good idea to invest in one.
Old Feb 10, 2003 | 09:00 AM
Vader's Avatar
AFAIK, the cam snout hasn't changed its bolt pattern since 1955. Are you checking it against the the cam that is in the engine, or a spare cam that you picked up as a replacement?
