seized lock
Old Feb 10, 2003 | 11:03 PM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
seized lock
how do u unseize a door lock my driverside is frozen but not from cold.
Old Feb 10, 2003 | 11:21 PM
H0TR0Dn's Avatar
Car: 88 Formula 350
Penetrating oil. Use the little red spout and spray it in the key hole, repeat. Try to spray on the backside of it too.
Old Feb 11, 2003 | 12:02 AM
Car: 86 Z28
Axle/Gears: TBD
thats what i been trying
Old Feb 11, 2003 | 12:24 AM
H0TR0Dn's Avatar
Car: 88 Formula 350
If that doesnt work you might see if something is jamming it. And last time i checked it wasn't very expensive to replace the locks. Not very hard either.
Old Feb 11, 2003 | 06:25 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I had a similiar problem on the pass side. The lock itself had corroded. Replacement was necessary. Since, I've used a product called, I believe, Lock-Ease. No problems. If it comes to replacement, while you're in the door, you might consider cleaning and lubing (with WD-40 and white grease) the power lock mechanisms and window tracks. Also, check for the rubber bump stops at the window track's bottom. They're probably lying uselessly at the bottom of the door. If you have door noise, check a thread of mine called "Pics and Observations' or something like that. Might help.
JamesC
Old Feb 11, 2003 | 08:53 AM
Vader's Avatar
Let's see... It was about 4°F in Chitown this morning. You really don't want oil in any of your lock cylinders. Once you get the lock freed, you might want to flush out all the oil you can with alcohol and apply dry graphite (the factory lubricant) so the locks operate easily in any weather.
Old Feb 11, 2003 | 06:15 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Originally posted by Vader
...graphite ...
One of my favorite lubricants... antiseize another.
jrdturbo
Mar 31, 2016 02:58 PM
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
kkirch15
Sep 30, 2015 04:44 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
