Comp Cams roller width
Old Feb 13, 2003 | 09:24 PM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
Any one have a set of Comp Cams Pro Magnum roller rockers and can measure the width of the roller. I have one slightly misaligned rocker where the narrow roller is a little off center on the valve stem. Since the heads are the narrow slotted guide in the head type there is no easy fix. I would think a wider roller
and steel construction of these roller rockers could make this a bolt on fix.
Old Feb 14, 2003 | 06:04 AM
ede's Avatar
ede
i have soem spare 1318's in the garage i'll check when i get out there. if i don't reply again in a day PM me so i don't forget. the 1318's are SA rockers, not sure if that'll matter or not.
Old Feb 14, 2003 | 06:41 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
.3775" ....
They're not supposed to be perfectly centered, or flat. They're supposed to ride around the edge of the valve slightly, to try to make the valve tend to rotate.
As long as the roller is on the stem, it's probably OK.
Old Feb 14, 2003 | 10:53 AM
84305HO's Avatar
Car: 84 Z28 Camaro
Engine: 350ci
Thanks guys......
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
