jammed lock?
Old Feb 15, 2003 | 01:23 PM
Mshrmhd's Avatar
Car: 91 Z28
Engine: F 305-205 (LB9)
jammed lock?
i dont know if my lock is jammed or if it is some kind of safety feature? i have an automatic tranny, so you have to push the button down to be able to shift. and i got a neon shifter light, made a bar that fits into the shaft and tightened the shifter down so it is acting as if it is pushing the button in. cuz it was a cheap plastic **** from wal-mart and i didn't want to keep having to push down on the plastic, cuz im sure ti would break soon...
anyways, i know, and dont care that i have to leave the key in my car because with the **** being pushed down it doesnt let the key come out .. probably a safety feature im sure... but a day after i put that shifter **** in my driver side door lock is jammed. i have power windows , when i hit lock it locks the passenger door, and the driver side door just makes a click sound. if i try to manually lokc the door, it doesnt move.. i didnt really wanna shove it hard incase it has somehting in the way or soemthing and bending the lock bar.
i took the shifter **** off and tried locking the door, neither worked (power or manually). so now i have to leave my driver side door unlocked, i dont like that at all.. am i gonna have to take apart my door to try and fix this? or is there an easy way?
also if i do have to take the door apart, how the hell do you get the black part on the top of the door panel off? my 82 camaro i got off pretty easy... but it wouldnt go back on ... it busted in 3 pieces... guess i pulled too hard?
i have a 90 RS it has the VATS thing... power locks ... manual windows. dont know if there is anymore info you guys will need, if there is just lemme know thanks alot.
jrdturbo
Mar 31, 2016 02:58 PM
kkirch15
Sep 30, 2015 04:44 PM
Damon
Sep 26, 2015 04:29 PM
Dragonsys
Sep 25, 2015 03:51 PM
