Compression
Old Feb 21, 2003 | 11:04 PM
deepstage69's Avatar
Car: '92 RS, '84 Z28
Engine: 383, L69
Transmission: T56, 700R4
Axle/Gears: 3.42, 3.42
Compression
What would the compression be, if i had 67cc heads, on a 350 with pistons that were dished and had valve reliefs?
I know you can be for sure without other measurements, but i just neeed and estimate.
Kevin
Old Feb 22, 2003 | 12:05 AM
kfoley's Avatar
Car: '85 Z28
Transmission: WC T5, 3.23 posi
We need to know how big the dish and valve reliefs are. That makes a huge difference in compression ratio.
Old Feb 22, 2003 | 12:13 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Once you find all the measurements you need, you can go here www.smokemup.com and use their compression calculator.
Go check it out first and you'll see how intricate ACTUALLY MEASURING for compression is.
Old Feb 22, 2003 | 05:16 AM
85TPI400's Avatar
A 350 with flat tops and 64 cc heads is usually in the neighborhood of 9.5 to 10.2-1, it would at least be less than that!
Old Feb 22, 2003 | 02:12 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
between 8.45:1 and 9:1.
just right for a blower...
FormulasOnly
Jul 23, 2018 08:47 AM
69GTOby
Apr 18, 2016 02:34 PM
Nervous2
Oct 8, 2015 10:53 PM
Jonas Earl
Sep 27, 2015 07:39 AM
WhteRbt
Sep 21, 2015 09:48 AM
