Question about tune up!
Old Feb 21, 2003 | 11:11 PM
91CustomRS's Avatar
How much will it cost to get a tune up for a 1991 Camaro RS?
And, how much would it cost for a Fuel Filter and plugs to go along with it.
Service as well.
Brian
(Sorry, I just posted this, and no one replied I press the wrong button and posted this accidentally.) But, reply to this one instead pls.
Old Feb 21, 2003 | 11:21 PM
GTATransAM's Avatar
Car: 1987 Trans Am GTA
Engine: 5.7L 350 V8 TPI
Transmission: Automatic 700R4
Well for a FULL Tune-up, your gonna need the following:
Spark Plugs
Ignition Wires
Oil Filter
Air Filter
Fuel Filter
Coil
Cap
Rotor
PCV Valve
Oil fluid change
Transmission fluid change
Rear-end fluid change
U can also add if u want:
Thermostat
O2 Sensor
Id say everything is gonna running u around $200 just for the products, for service id say at least another $100, IF there gonna do everything. Though i recommend if u know your way around an engine, and are handy with some tools, to go ahead and do most of that stuff yourself. Trust me, u save money, and learn things too.
Fuel filter should be no more than $10, and plugs no more than $4 each.
Id just got done doing a FULL tune-up on mine, and i still have the transmission and rear-end fluid to do, but everything else is done. It cost me more than $200, but i did get MSD cap, rotor, and coil, and installed everything myself.
But that should be most of it, if i forgot anything, someone else here should fill u in.
Good luck!
Old Feb 21, 2003 | 11:43 PM
bubbz89's Avatar
Car: 1990 RS
Transmission: TH-350
do it yourself. nothing like the feeling that you know everything was done right.
Old Feb 21, 2003 | 11:48 PM
91CustomRS's Avatar
Hello,
I would do it...but, if I did it...the car would no longer be running heheh.....
I know nothing about the engine ect of the car.
brian
Old Feb 21, 2003 | 11:53 PM
bubbz89's Avatar
Car: 1990 RS
get a haynes repair manual man, its real easy stuff to do. it will be a good learning experience.
Old Feb 21, 2003 | 11:54 PM
91CustomRS's Avatar
I dont know...ehe...I really dont know much about this stuff...I literally dont know ANYTHING about under the hood hehe....
brian
Old Feb 21, 2003 | 11:55 PM
bubbz89's Avatar
Car: 1990 RS
you stick around this board long enough and you will learn alot man, i know i sure did.
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
theurge
Aug 21, 2015 12:46 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
