Tech article on air pump removal not helpful
Old Feb 23, 2003 | 05:37 PM
trans92's Avatar
Car: 1992 Trans AM
Engine: LB9 305 TPI
Transmission: 4L60
The article in the tech section about rerouting is a little confusing, I dont see any power stearing. Anyone know how I can remove my air pump, but keep the power stearing (305 V8 Trans AM). What # belt do I need then and how should I reroute it. Thank you
Old Feb 23, 2003 | 05:46 PM
vjo90RS8's Avatar
Car: 2002 Z28
you should be able to just route it the same as you did before you removed the air pump, u will just need a shorter belt
specialized
Jun 18, 2022 09:26 AM
mustangman65_79
Apr 14, 2017 05:37 PM
TheExaminer
Aug 26, 2015 04:59 PM
3rdgenparts
Aug 8, 2015 07:09 PM
