heater and washer sprayer
Old Feb 25, 2003 | 02:06 PM
CamaroFreak85's Avatar
Car: 1985 Camaro
Engine: 5.7, Vortec heads, Headers, TBI
Transmission: Built 700R4
Axle/Gears: 3.23 BW 9-Bolt Disc Brake
My heater doesnt work and i found that the ground wire isnt connected some where in the wire bundle where does the wire go and where does it ground i have removed the stock computer, i dont think that will make a differece and also my washer sprayer doesnt work would it be grounded to the same wire or what? any info would be great thanks
Old Feb 25, 2003 | 02:37 PM
snakeskinner's Avatar
well, without knowing what circuit that is I can't tell. You need to get ahold of a service manual to help you. Does the blower motor work or the heater just not blow hot? more than likely the washers are failing from a separate problem. where is this ground wire at and what does it look like?
Old Feb 25, 2003 | 02:49 PM
Merlin's Avatar
The heater blower motor has a ground wire connection at the upper left corner of the blower housing (as viewed from the front). the opposite end of this ground wire connects to the chassis at the firewall, behind the right cylinder head (along with a lot of other engine grounds).
Old Feb 25, 2003 | 06:11 PM
definitely, this needs to be connected to ground but it won't have any affect on the washers.
Old Feb 26, 2003 | 08:48 PM
Car: 1985 Camaro
thanks for the info ill check all that out
Fireslash
Apr 11, 2016 06:43 PM
Formula8r89
Sep 22, 2015 04:24 PM
