Which Vortec manifold?
Old Feb 28, 2003 | 04:09 PM
Hodge's Avatar
Car: 1987 IROC-Z28
Engine: 383 Vortec - carb
Transmission: T56 - 6speed
I'm building an engine (either 350 or 383) with Vortec Heads and a single Holley 750 carb. I want to use a standard 14" airfilter housing. I haven't selected a manifold yet and I'm looking for input to help me decide which one to get. I'd like to be over 400HP. this is a street/strip car so it needs to have some road manners and I'm looking at cams with lift numbers around .525 and durations in the 210/220 range
are there any that won't clear the stock hood? (too tall?)
are some better than others? why?
marc
Old Feb 28, 2003 | 04:42 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
The Performer RPM is probably what you want, but it won't fit unless you use a drop-base aircleaner base. No big deal with a drop base and a 14x3 airfilter. I'm running that on my Vortec 350. I don't think the Victor Jr (or is it Super Victor?) for vortecs will fit either (probably wouldn't fit even with the drop base aircleaner setup, not sure). About the only thing that will fit is the standard Edelbrock Performer, which will cost you a few ponies vs the RPM intake...
Old Feb 28, 2003 | 07:03 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The performer rpm is the intake you want.
It will fit under hood with a drop base air cleaner.
The best one is the one used on 60's 70's corvettes and
camaros.
The cam is too small for 400hp get one with 218 to 226@.050
duration. It will still have good street manors.
The performer is lower but will not make as much top end power.
As an alternative, check out Professional Products
stuff.
www.professional-products.com
They have 3 vortec intakes available.
The GM aircleaner base looks like this ----
You can still buy it from restoration sources
Allows a 14x2.5" filter with room to spare.
Old Mar 2, 2003 | 08:14 PM
Hodge's Avatar
Car: 1987 IROC-Z28
ttt
Chas91Z28
Oct 22, 2015 10:12 AM
Quzyle
Oct 15, 2015 03:35 PM
monte87cortez
Sep 26, 2015 08:10 PM
Liveaction
Sep 17, 2015 06:29 PM
