Quick question on Holley carbs
Old Mar 2, 2003 | 07:33 AM
chymos's Avatar
when swapping a Holly from a 305 onto a 350, is any work needed other than just taking it off one and putting it on the other?
Old Mar 2, 2003 | 09:10 AM
Vader's Avatar
To do it properly, you'll probably have to change the main jets and power valve (unless it was over-jetted for the 305). You'll almost certainly have to adjust the idle mixture rate.
Old Mar 2, 2003 | 09:31 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Holley claims the idle mixture srews once set are near perfect for any setup and the only change nessasary are jets and possibly power valves. Depending on how different this enigne is compared to the other it may not need too many adjustments. like Vader touched on it may have been jetted rich in the past. Factory Holley settings are on avarage 2% rich so it may be just right. I could slap my Holley on just about any engine and it would be fine without changing anything.
Frozer!!!
Jan 19, 2024 04:55 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
