Holley 4160
Old Mar 6, 2003 | 07:00 PM
chymos's Avatar
Holley 4160
would a Holley 4160 need a rebuild after being installed on an engine with an out-of-phase distributor?
if so, what parts in particular should be looked at?
Old Mar 6, 2003 | 07:49 PM
chymos's Avatar
Hmm. Now that I've noticed the Carb board, this should probly be moved there....
Old Mar 7, 2003 | 12:12 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
If it backfired during this episode, the power valve may have blown out. Most later carbs have a check valve to protect it from that, though.
Old Mar 7, 2003 | 04:40 AM
chymos's Avatar
so the power valve is the only part that might have been damaged?
and yes, it did backfire several times.....
Old Mar 7, 2003 | 09:38 AM
Vader's Avatar
And if you do get a replacement power valve, try to get one with elongated slots in the fuel passage stem instead of one with the series of drilled holes. A power valve is supposed to allow more fuel flow, and the little holes don't do that as well as the slots or "windows".
RaverRacerX
Mar 17, 2026 01:49 AM
F.I. 57 Belair
Aug 23, 2021 01:09 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
dusterbd
Sep 29, 2015 08:40 AM
