more 1/4 mile time questions
Old Mar 9, 2003 | 01:31 PM
badazz84camaro's Avatar
ok, i now you guys answer alot of these questions, but i need some opinions on what i should run and if me combo is set up right. i have a 350, 10:1, world s/r torquers ported and polished, 3 angle valve job, comp xe-268, 1.6 rockers, hedman shorty hedders with y-pipe, hooker catback, 3000 stall with th-350 tranny, 3.73 gears, suspension fully updated, rpm air gap, 750 holley
Old Mar 9, 2003 | 07:24 PM
jimmy_mac's Avatar
Re: more 1/4 mile time questions
You should run some good tires on the rear. like some Nittos or something. I think your combo is probably good for mid 13s conservatively if you hook up. With the 3000 stall that won't be easy.
Old Mar 9, 2003 | 09:26 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
High 12's on slicks if you get the carb and timing dialed in. Low to mid 13's if not on slicks.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
kyle5647
Aug 7, 2015 03:08 PM
